NI Home
Cart Cart | Help
You are here:
Reply
Member
jeanbat29
Problem of stability and precision measurement of voltage under MAX
My goal: To acquire a voltage output by an LVDT.
The meter or using an agilent I have a measuring accuracy of the order of 5mV.
By cons, using two different cards: PCI 6013 or 6014 + CB68LP terminal and different ways (test on two different PCs):
The MAX test panels do not give me that accuracy of the order of 100mV! Therefore impossible to obtain sufficient accuracy with the LVDT.
Big noise, but where does it from??
Conf. Labview 2010, DAQmx 9.2.2
Help !!!!!
Active Participant
SAMUEL_NIF
Re : Problem of stability and precision measurement of voltage under MAX
And thank you for posting here.
Could you explain more your configuration?
What is your input configuration (NRSE, DIFF, GRSE) ?
You can take a look on this link :
groud loops and returns
Samuel G.
Samuel G. | Certified LabVIEW Associate Developer
National Instruments France
Journées techniques : des fondamentaux aux dernières technologies pour la mesure et le contrôle/comm...
Member
jeanbat29
Thanks for your answer.
The Mode is : On demand
Input Configuration: Differential
I had a look to the group loops and returns but... with a simple multimeter I have a good accuracy at the wire at the output of the signal, with MAX...no!
My Profile | Privacy | Legal | Contact NI © 2011 National Instruments Corporation. All rights reserved.    |    E-Mail this Page E-Mail this Page
