02-17-2010 01:57 AM
Hi
I'm trying to replace an application built on a B&K Pulse sytem. As part of the signal analysis they have used a Phase Assigned Autospectrum which is a tool B&K used for Operating Shape Deflection Analysis. There are no references to this on the NI site and very few on the web at all. This document from B&K seems to be about the best explaination I can find http://www.bkhome.com/downloads/PULSE%20Operating%20Deflection%20Shape%20Analysis.pdf
Has anyone heard of it or know how to implement it in Labview?
PS. The input is 3 accelerometers mounted on a component inside of an assembly that is being vibrated. We need to calculate angular change of the component ignoring the movement of the assembly.
02-19-2010 03:01 PM
Hi Snowboarder,
Is the Phase Assigned Autospectrum collecting the data from the accelerometers? If not what is collecting the data and what exactly is the Phase Assigned Autospectrum? Unfortunately I was unable to view the link you posted. Can you provide more of an explanation of your hardware set up?
