Dynamic Signal Acquisition
Phase Assigned Autospectrum (PAS)
Hi
I'm trying to replace an application built on a B&K Pulse sytem.  As part of the signal analysis they have used a Phase Assigned Autospectrum which is a tool B&K used for Operating Shape Deflection Analysis.  There are no references to this on the NI site and very few on the web at all.   This document from B&K seems to be about the best explaination I can find http://www.bkhome.com/downloads/PULSE%20Operating%20Deflection%20Shape%20Analysis.pdf
Has anyone heard of it or know how to implement it in Labview?
PS.  The input is 3 accelerometers mounted on a component inside of an assembly that is being vibrated.  We need to calculate angular change of the component ignoring the movement of the assembly.
(7,287 Views)
Hi Snowboarder,
Is the Phase Assigned Autospectrum collecting the data from the accelerometers?  If not what is collecting the data and what exactly is the Phase Assigned Autospectrum?  Unfortunately I was unable to view the link you posted.  Can you provide more of an explanation of your hardware set up?
h_baker
Applications Engineer
(7,267 Views)
