NI Home
Cart Cart | Help
You are here:
Reply
Member
Adam S Carney
NIDAQ is getting too big!
NI is becoming like Microsoft! I realize that you manufacture many products but the time for device specific NIDAQ packages has come. I use one of your devices but I am forced to download and distribute a driver package that is almost 1GB and takes nearly an hour to install. Please, please, please change this. Let us get packages for just what we want! Small, simple and quick is good. Big, complex and slow is bad.
Adam
Member
Alex A.
Re: NIDAQ is getting too big!
In order to gain the full functionality of DAQmx, the full download is required in order to ensure compatabilty and functionality across platforms.  An example is the DAQ Assistant in LabVIEW, with individual drivers, each instrument would need its own Assistant and LabVIEW pallettes.  If you need smaller run-time engines of DAQ drivers, we have some avaiable without varying degrees of functionality here.
Alex A.
Applications Engineer
Member
Sinha
HI Alex
I would wish following:
1. A regular on-line upgrades with min downloads like anti virus software firm implement. This can help upgrade DAQ drivers without having to endure for hours after putting a new DAQ driver CD.
2. A device(s) sepcific dowloads or installation to minimize the implementation of DAQ in target PC and only its upgrade.
Sunil Sinha
Member
Neal M
Hello Sunil,
It was decided by our R&D department to use the same driver for a majority of our hardware and make it as easy to use as possible.  This way, as Alex said, using similar devices would not require major (or in some case any) changes in code, and new applications would be easy to program by someone familiar with any of our other devices.  It also simplifies troubleshooting, reduces the time to configure new devices (after the first), and makes sure that all hardware is supported to the same high level our customers expect.
A side effect of this decision (and the major issue with this approach) is that the initial install is large and takes significant time.  I agree that this can be annoying, however after completed once, it should not have to be done again when installing new devices.  Upgrading, although it is a large file, should not take nearly as long since it only changes the parts that it needs to, or installs parts that are not there.  You can also unselect the drivers you do not use from the Driver CD installer to shorten the time further.
The main reason that we cannot have a simple anti virus-like update is due to the changes we are making for the upgrade.  It is not just updating settings or libraries, it is changing parts of the actual driver code deep within the program.  It is more comparable to a new version release of the anti-virus software than an update to the virus definitions.
Since the DAQmx driver is used for most of our hardware (or the driver that is used is based off of it), the install/upgrades we have are as device specific as they can be.  The driver CD contains all of our drivers, but allows you to choose which it installs/modifies.
If you are deploying the driver to a target computer, you can drastically reduce the size of the installation by choosing a smaller runtime of the DAQmx driver.  The link that Alex provided, as well as this Developer Zone article discribes how to do that.
This being said, we are always looking for feedback on how we can improve.  I would strongly encourage you to make a Product Suggestion about this. R&D looks at all of these and uses them in their decision making processes.  I hope this explanation shows that we are not just giving you a large download because its easy for us, but we believe the pros of this method we use outweigh the cons (including the installer).
Neal M.
Applications Engineering       National Instruments        www.ni.com/support
My Profile | Privacy | Legal | Contact NI © 2011 National Instruments Corporation. All rights reserved.    |    E-Mail this Page E-Mail this Page
