NI Home
Cart Cart | Help
You are here:
Reply
Member
Re: NI-DAQmx Multiple Tasks on one card?
Yes, it is possible. When I run your code I get the results I expected (sinewaves on ai0 and ai1). Below is a screenshot of the acquired data. Did you have a separate VI for acquiring the signals for validation?
Doug
NI Sound and Vibration
Member
palpro
One channel of my analog scope broke...  I had thought that these analog equipments outlive digital stuffs, but I was wrong.  Thanks for testing out the code.  I really appreciate that.
Member
aghacker
[ Edited ]
This thread was quite informative but outdated. I want to know if anything has changed since 2004 with the ability to run multiple tasks on the same device. I have cDAQ-9188 which can supposedly run 7 different generations/acquisitions at the same time. I also have an NI 9264 analog output module. I had hoped to group a few channels together in one task that generates DC, and also create another task that generates waveform data. So far it claims that the device is busy if I try to run more than one task at once, even though tasks do not share channels. Is a single module still only capable of a single sample rate?
My Profile | Privacy | Legal | Contact NI © 2011 National Instruments Corporation. All rights reserved.    |    E-Mail this Page E-Mail this Page
