Hello Gerald
I am using the BNC-2110 to make my conections and
according to the manual, this accessory already have
the resistor.
The analog lowpass filter is an old (but working fine)5489A from HP. Frequencies above the cutoff
are attenuated at 12dB/octave. I have checked it.
I don´t know the order of the filter.
I didn´t mention but my region of interest is from
1.0 to 6.0 Hz where the magnitude of the CPSD is constant (white noise). In this region, is the effect
of aliasing so high?
Just remember that is the number of averages in a block
or set that causes the wrong result. With a block with 2 averages the result is wrong but with 5 averages the
result is right. So, I think, aliasing is not the
problem.
One more infor
mation: I used the signal generation of
the board to generate a gaussian white noise very
similar to the real signal and all the conditions were
identical the experiment. The gaussian noise was generated in a range of frequencies from 50 to 2kHz.
In this simulation, no problem have occurred!!
The final result (100 averages) was identical with
50 sets 2-averaged, 20 sets 5-averaged, 10 sets
10-averaged or 100 averages directly.
In other words, our real signal has something different from the generated signal.
It is a very interesting problem, isn´t it?
Regards
Ricardo.
