09-01-2009 02:05 PM
I have a LabVIEW v8.5 application that utilizes a NI 9233 module to input signals from accelerometers. This module has IEPE excitation and AC coupling always enabled.
There is a new module, NI 9234, that is being pushed as a replacement for the NI 9233. It can have IEPE excitation enabled or disabled, it can have AC coupling or DC coupling; these items are now software selectable.
What is the default setting for IEPE excitation and AC coupling for the NI 9234? Is it drop-in compatible with the NI 9233, vis-a-vis my LabVIEW application, or will it require the application to be modified to initialize the module to IEPE enabled, AC coupled?
09-08-2009 04:07 PM
lgk,
As you can see here the 9234 is Default AC Coupled. For applicable tasks like Accelerometers IEPE is by default enabled at 2mA. It should be pretty much a drop in obviously it will have to be selected by the program oter than that it shouldn't requrire to much else.
