NI Home
Cart Cart | Help
Hello Events Academic NI Developer Zone Support Solutions Products & Services Contact NI MyNI
You are here:
NI Home > NI Developer Zone > NI Discussion Forums
Reply
Member
thinker-1
How to use Port I/O Daqpad-1200 as an index to array for analog acquisition
I use DaqPad1200 which has two Analog inputs.
I use an external cmos analog MUX to scan a 2D  array of sensors (x and y).
The digital output ports are used to address the Row column MUXes.
The Analog acquired data should go in the array so the port values are the the array indices.
Any idea on how to do this?
Member
Carmen_Martinez
Re: How to use Port I/O Daqpad-1200 as an index to array for analog acquisition
If I well understood your requirements, you can create the digital signal to control your mux by using something like this (see attached picture).
If your MUX has less than 8 bits you can modify the code to write only the amount of bits needed.
What else does your application need? It would be useful if you can explain it with more details.
Member
thinker-1
Thank you for taking time to consider my issue.
I am a beginer , actually I was.... then I could solve this by reading examples and it is mazing how easy it is !!
Building and displaying matrix arrays is very easy and useful. I remember the pointers in C and how difficult to manage they are.
The problem now is that execution is slow with respect to my needs.. i.e. Analog acquisition and multiplexing are taking milliseconds.
Is this a function of computer speed?
Can I make a stand alone application without the need to the PC? just like burning an Eprom to put on target system ?
THank you for any hint
Member
Carmen_Martinez
You are right, LabVIEW is a kind programming language...
For what you said, I think that the timing bottle neck could come from your hardware (DAQpaq is quite an ancient device).
What are your timing requirements? At which frequency you need to acquire your data?
You could use some hardware like cDAQ.
For stand-alone applications there is the possibility of using the cRIO platform.
Member
thinker-1
What I need actually is to make the analogue data acquisition remote and data analysis and visualisation, elaboration local on a PC.
Distance of the data acquisition point could be 5 to 10 meters. Data could also be sent over a network.
I need 2 - ADC and 2 DAC plus digital ports , just like the DAQPod1200.
Thank you for any specific suggestion !!
Member
Carmen_Martinez
[ Edited ]
I have several suggestions for you (cDAQ Ethernet):
http://sine.ni.com/nips/cds/view/p/lang/en/nid/209818
http://sine.ni.com/nips/cds/view/p/lang/en/nid/209925
http://sine.ni.com/nips/cds/view/p/lang/en/nid/208990
After what I read, I think this is what you are looking for. Hope this helps
By using this web site, you accept the Terms of Use for this web site. Please read these Terms of Use carefully before using any part of this site. Please go here for information on ni.com's copyright infringement policy.
My Profile | Privacy | Legal | Contact NI © 2011 National Instruments Corporation. All rights reserved.    |    E-Mail this Page E-Mail this Page
