Now I can use 4461 to AO signal continuously, but the structure of the program is based on the while loop.So if I want to stop the generation,I must click the "stop" control on the front pannel.What I really want to know is if there is a method which isn't based on the while loop,thus when I run this vi, it can generate signal continuously.Because this vi isn't based on the loop, 4461 can still generate signals even though I closed this vi.And if I want to stop generation, I can run another vi to stop the generation. It will be better if there exists such a method. So I can program using TestStand. One step is signal generation, and next several steps will stop the generation.
Thanks a lot!
