Dynamic Signal Acquisition
Generation of Square and Triangular wave using 4461
I want to generate 0.01Hz square and triangular waveforms using NI 4461 card. How to generate such wave forms using LabVIEW ?
Bhaskar
(7,004 Views)
recommend that you start with an example such as <LabVIEW>\examples\DAQmx\Analog Out\Generate Voltage.llb\Cont Gen Voltage Wfm-Int Clk-Non Regeneration.vi
http://decibel.ni.com/content/docs/DOC-3545?nisrc=LV-2009
Message Edited by dsb@NI on 06-15-2010 01:34 PM
Doug
NI Sound and Vibration
(6,999 Views)
Hi
  I have to generate 20kHz traingular wave in labVIEW.I was generated the signal using the signal generator but iam not getting the proper triangular waveform.So please give me the solution  for how to generate the traingulr waveform of 20kHz   in labVIEW
(5,904 Views)
