06-15-2010 08:57 AM
I want to generate 0.01Hz square and triangular waveforms using NI 4461 card. How to generate such wave forms using LabVIEW ?
Bhaskar
06-15-2010 01:29 PM - edited 06-15-2010 01:34 PM
recommend that you start with an example such as <LabVIEW>\examples\DAQmx\Analog Out\Generate Voltage.llb\Cont Gen Voltage Wfm-Int Clk-Non Regeneration.vi
http://decibel.ni.com/content/docs/DOC-3545?nisrc=LV-2009
05-13-2014 12:26 AM
Hi
I have to generate 20kHz traingular wave in labVIEW.I was generated the signal using the signal generator but iam not getting the proper triangular waveform.So please give me the solution for how to generate the traingulr waveform of 20kHz in labVIEW
