Currently the PCI-4452 is only supported under the following programming environments.
LabWindows/CVI
Visual Basic
Visual C/C++
One option you may want to consider if you need to run your application in TestPoint is to create a dll from within one of the above mentioned programs and call the dll from TestPoint.
Brian
