Dynamic Signal Acquisition
Analog inputs voltage effected each other
I'm using a NI PCI-6070E adc card with a sc2345 series carries. Now two channels are used, one of them is 1-Channel Thermocouple Input Modules (SCC-TC02) the other one is differential input (+10 V, -10 V; without any module). When differential input goes +10 volt or -10 volt level suddenly, temperature measurement is effected and goes crazy. I want to solve this problem. Thank you in advance.
(7,230 Views)
Hello erinc,
The 6070E channels are not completely isolated from each other and since your thermocouple measurement is very low voltages, a little noise will throw off your accuracy considerably.  Try moving the ±10V signal to the channel furthest away from your thermocouple and see if that helps at all.
ColeR
Field Engineer
(7,217 Views)
Hello ColeTrain,
Thank you for your quick suggestion. I've already tried that but it did not work.
(7,170 Views)
Hey,
Here is a another thing you can try,
Connect - Thermocouple to Channel 0
Connect Channel 1 - AI Ground
Connect 10V diff signal to Channel 2
Conncet Channel 3 - AI Ground.
This will provide path to the internal capacitor for S/H ckt to discharge and will remove ghosting. Look at this knowledgebase for more information.
NI-khil
(7,154 Views)
NI-khil,
Thanks for the KB, but the link happens to be internal to NI.  For anyone outside of our network, you can go here to see the KB NI-khil posted.
ColeR
Field Engineer
(7,139 Views)
