Hello everyone
I am using the PCI 7344 card.Under windows system I use the flexmotion32.dll well with vc,but when I use it under rtx ,it does not work,appering " can not load the driver".The fact is ,as most say,the driver is not suitable under non-windows systems. So I wonder
if there is driver under the rtx,or how to use the windows driver under the rtx.
If it is necessary to develop my own motion driver,what can I do?Does 7344 support register lever programming ? If it does, Can I get the register map of the 7344?
Hope your reply!!
Thank you!!
