01-10-2006 03:45 AM
01-10-2006 05:17 PM
Just to clarify, you are looking for an instrument driver to run on a PDA and communicate with a desktop/benchtop instrument (the Metex M3890D)? Have you been able to communicate with the Metex M3890D from a PC? I notice it has a "RS232C PC interface via USB" - does that mean you have to connect it to your PC via a USB port, but then you use RS232 commands? The reason I'm asking is because you can use serial compatability VIs on PDA to communicate via the serial port ( Can I Implement Serial Communication With My PDA Device? ), however you cannot use VISA, which is typically required to successfully communicate via USB ports to other devices. Could you please let us know if you've had any success connecting to the instrument from something other than a PDA?
Logan S.
01-11-2006 02:49 AM
01-12-2006 01:36 PM
