I am using the DAQCARD-AI-16XE-50 and NI example code working on CE .net system with hardware PC104. After I set up the system, and run the sample code from NI(aiex1), it always return 65535 in the loop to check the stack. What is wrong? anybody knows why?
Thank you in advance for your help.
