10-23-2009 04:54 AM
Hi to all,
i successfully used my NI E series PCI card with MHDDK and RTX (using OSIbus implementations for RTX and E series MHDDK examples). Now i try to
use it with the INtime samples provided on NI website. I'm sure that my NI card ID
string is "PXI5::9::INSTR" (works well with RTX), the lsdaq sample (which scans for PCI hardware with NI Vendor) returns me
"PXI5::0::INSTR" but both values failed to init the card using
example.sln (AcquireBoard) : device is not found (PciFindDevice fails).
Do you have any clues where the problem comes from ?
Thanks in advance,
Antoine Nourry
Solved! Go to Solution.
10-23-2009 05:38 AM
10-23-2009 05:39 AM
