Driver Development Kit (DDK)
Instead of using the make file can you build nirlpk.sys using MS WDK 8.0 on VS2012?
After downloading the NI nimhddk_windowsWDM-2 and -1
Instead of using the make file I built nirlpk.sys using MS WDK 8.0 on VS2012
I copied the source files out of the dir /nirlpk to the MS template for WDM drivers
It built after turning warnings as errors off.
After uninstalling the NI_DMX driver I tried to install the RLP driver that consisted of nirlp.inf and nirlpk.sys
I got this message:
Windows found driver software for your device but encounted and error while attempting to install it.
PCI-6602 RLP WDM
Driver is not intended for this platform
Is the nirlp.inf file correct for loading on Windows 7 64 bit?
Any ideas?
Message 1 of 1
(6,356 Views)
