[Thanks again to the NI engineers that have prepared the X Series support for the MHDDK. Your work is much appreciated!]
I've been reviewing the X Series DDK manual and example code to get a handle on how things work, and I have
a couple questions about the calibration data that's retrieved from the EEPROM via eepromHelper and how it is used.
1) There are 4 AI "modes" containing 4 coefficients. What do these modes refer to? Do they have anything to do with different
ground reference modes (DIFF, RSE, NRSE)? I noticed that eepromHelper::getAIScalingCoefficients() only uses the coefficients
for the first mode (mode 0) to compute the scaling coefficients for a given voltage range. Is that OK no matter which ground
reference mode my application employs?
2) There is one AO "mode" containing the usual 4 coefficients. The eepromHelper reads in this mode as well as the different
voltage interval (gain, offset) pairs, but it doesn't use the mode coefficients to compute the scaling coefficients for a given
interval as is done for AI and as is implied in the DDK reference manual on p. 2-18. Instead, scaling coefficients are simply
the gain (C1) and offset (C0) for the chose voltage interval. Is the mode not relevant in the case of AO?
Sincerely,
Scott
