le 09-21-2015 07:12 AM
J'ai fait un vi avec une addition sur le pc 32bits en mettant l'exe sur le 64 ça ne marche pas
le 09-21-2015 07:19 AM
et tu as le message "no supported languages installed" lorsque tu cliques sur l'exe?
Luc Desruelle | Mon profil | Mon blog LabVIEW | Auteur livre LabVIEW : Programmation et applications - G Web
Certified LabVIEW Architect (CLA) & Certified TestStand Developper (CTD) | LabVIEW Champion
MESULOG - LinkedIn site | NERYS - NERYS Group
| directeur CEO MESULOG
| CODIR - NERYS group
le 09-21-2015 07:20 AM
si ouii c'est le RunTIme LV 32 bits qui est la cause.
tu peux regarder? cela (c'est pour LV2009 mais teste)
LabVIEW Built Applications Display Chinese Characters
Occasionally after running an NI installer that updates a LabVIEW Run-time Engine, LabVIEW built applications will display Chinese characters. This includes Distributed System Manager, VeriStand and user built applications. The problem is that a resource file that is used for translation is not installed correctly. If you are on a deployment system and you haven't installed the Run-Time Engine Non-English Support you could receive "No Supported Languages Installed" when running the application.
Workaround: Go to \Shared\LabVIEW Run-Time\2010\English. There should be a temporary file there named something like "TBMAE0D.tmp". Rename this file to lvapp.rsc. If there isn't this file you can copy it from another installation. This error can occur if you don't reboot your machine after installation.
Reported Version: 2009 32-bit | Resolved Version: 2010 32-bit | Added: 04/20/2011 |
| CODIR - NERYS group
le 09-21-2015 07:22 AM
ou celui-ci
..., then it looks like this is an error due to installation issues in the run-time engine. Try to perform a repair by going through the install menu of LabVIEW. The following link will help you with the repair: http://digital.ni.com/public.nsf/allkb/FE6B641E86E55AF2862576DE00038001?OpenDocument
| CODIR - NERYS group
le 09-21-2015 10:19 AM
SUPER!!!!!! ça marche
Un grand merci pour ton aide et le temps passé
A+
Eric
le 09-21-2015 10:47 AM
A+
Eric
cool.... mais la solution c'est quel post????
nous sommes sur un forum donc peux-tu :
> noter le bon post solution (quel réponse permet de répondre à ta question)
> mettre des kudos pour me remercier!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
| CODIR - NERYS group
le 09-21-2015 12:38 PM
Salut,
Desolé j'ai pas l' habitude.
C'est en réparant nidist.id que ça marche (tuto: http://digital.ni.com/public.nsf/allkb/FE6B641E86E55AF2862576DE00038001?OpenDocument )
Merci pour l'info
A+
le 09-21-2015 02:11 PM
salut et merci pour le retour.
Sur un forum il faut penser à donner des "kudos" (=merci) et permet de savoir si le post est pertinent.
Je t'invite sur les autres posts que tu as ouverts de mettre quelques Kudos. Regarde les autres posts.
A+
| CODIR - NERYS group
