Discussions au sujet des autres produits NI
annuler
Affichage des résultats de
Rechercher plutôt
Vouliez-vous dire :
USB-6000 + NIDAQmx + QT
Résolu !
Accéder à la solution
I'm looking for the USB-6000 device and i wonder if it's possible to use it with QT creator (C++) using the NIDAQmx driver ?
https://www.ni.com/en-us/shop/model/usb-6000.html
Thanks.
0 Compliments
Message 1 sur 3
3 240 Visites
Accepté par l'auteur du sujet clemon
You're here on the french board. Your question is about the NI DAQmx driver support, so a better place to request support is the Multifunction DAQ board (Discussion Forums » Most Active Hardware Boards » Multifunction DAQ).
I think yes, it is possible. NI DAQmx can be used from C/C++ development environment.
You will find help for the driver, with function reference on this page : https://www.ni.com/docs/en-US/bundle/ni-daqmx-c-api-ref/page/cdaqmx/help_file_title.html
Message 2 sur 3
3 227 Visites
I can affirm that it's compatible with QT and very easy to use.
Good product.
0 Compliments
Message 3 sur 3
3 143 Visites
