le 05-20-2015 01:56 AM
hi,
how to get combobox index value and i know easly get index value in enum but i can't use enum in my application.i want both combobox value and index number.
Résolu ! Accéder à la solution.
le 05-20-2015 02:32 AM
Hi madhanskm,
you're here on the french speaking forum, if you want to write in english it's better on the english speaking forum.
If you want to obtain the index number of a combobox selection, you can use the property-node strings and search the selected string in the array of values.
le 05-20-2015 02:37 AM
You can too deselect the option "use string as values" and put item number, then convert the string-number to a real number, it could'be better.
