cancelar
Mostrando los resultados de
Buscar en lugar de
Quiere decir:
xbee por visa
Hi to all,
The most important relates to the fact that it receives values by USB cable (serial port) without problems but when I connect the XBEE (point to point connection) it appears the first value of the first sensor, even when selecting other. For example: If i select temperature sensor, apeears the value: 14.52.
Then appears the value 14. in other sensor.
What happened?
If you can help thank you!
Thanks to all!
Philip
0 kudos
Mensaje 1 de 1
4.330 Vistas
