el 08-04-2009 04:14 PM
I have a problem, I am using VI and designed to control a Fluke 9100 calibrator, but when I run the VI, the time the program expires and will not let me see the data sent. For example, if I want to generate 10 Vdc, and read the mark on a multimeter (device for calibrating) the calibrator only writes the mark, but doesn´t generated or makes it very fast only (and the multimeter doesn´t read the generated signal ).
How can I make this more prolonged period, or enable and disable it when I want.
Thank you very much
el 08-04-2009 09:16 PM
Foro Repetido:
http://forums.ni.com/ni/board/message?board.id=6170&message.id=10440&jump=true#M10440
Saludos
