el 06-13-2009 10:18 AM
el 06-15-2009 01:37 AM
Buenos dias,
Utiliza drivers Visa ( se encuentran en una carpeta con el mismo nombre, pon VISA en el buscador de LabVIEW).
Con el Write escribes los comandos que quieras al multímetro, con el read lees los datos que quieras.
Otra opción mucho mas facil, si dispones de drivers para el multímetro introduce la dirección RS-232 en LabVIEW en el Handler (seria esta algo similar a COM 2, COM 3 ...etc dependiendo el puerto utilizado en el PC).
Faltaria un configurar del puerto serial (pon "Visa configurer serial port").
Vaya bien !
el 06-15-2009 01:15 PM
el 06-17-2009 06:35 PM
Hi, thank you very much indeed for the replays. I would like, if it is posible, if you have some practical examples about programs which read some information from a multimeter, I have a multimeter at home... and I have some mesures in it... and i would like implementing a program to read that information. do you have some examples??? i give you my e-mail address if you could send me some of them... Thank you so much for your help, you can replay me in spanish, I understand.
aruiperez85@hotmail.com
el 06-18-2009 01:46 AM
Que modelo y marca de multímetro tienes?
el 06-18-2009 11:13 AM
I would reply in Spanish, but it probably wouldn't be very coherent
As far as examples go, I would recommend looking through our various Serial examples (Basic Serial Write and Read.VI and Advanced Serial Write and Read.VI are probably a good starting point). We don't really have any specific examples that I'm aware of that communicates with a generic multimeter. If your multimeter is IVI compliant, we do have IVI examples in our NI Example Finder under Hardware Input and Output -> Instrument Drivers -> IVI. You may want to check our Instrument Driver Network to see if we have any drivers for your multimeter as well.
el 06-19-2009 11:01 AM
el 06-19-2009 07:32 PM
Hi again... thanks to all of you, you are very kind, I have escort 3145A, i dont need drivers... because i can conect it and my computer detects it, what i want it is only several examples in labview program, to read.. for example some data from the multimeter like for example... volts... or Hz or amps...
I only need .vi files, i mean examples in labview. i have the rest hehe. I only need to understand how it works with examples... how the program reads data from a multimeter... i have an example but i need more hehe xD.
Thank you very much in advance... you are very kind to replay me.
Regards
el 06-23-2009 10:31 AM
