el 12-10-2012 08:37 AM
I have configured a step in my TestStand 2010 sequence to call a LabVIEW 2010 (SP1) VI that contains several VIs
contained in vi.lib.
My sequence executes successfully when I’ve configured the LabVIEW Adapter to execute VIs using the LabVIEW development environment, however, when I change the LabVIEW Adapter to execute VIs using the LabVIEW run-time engine, the system lasts a lot of time to make
it first execution (like if it was trying to find all files used in vi.lib and recompile them).
I've tried to make a mass compile in vi.lib and inst.lib, put those directories (and its subdirectories) in the search directory in teststand, but always do the same
How can I resolve this problem?
el 12-21-2012 10:19 AM
Hi langles
This is the spanish forum, please post your question in the TestStand discussion forum .
Diego
