el 02-04-2012 10:52 AM
hi ..
please can help me with the link to download the toolkit RGT (report generation toolkit) for windows 7 x64.
I installed the drivers .. but I can not install some packages
In the address <http://zone.ni.com/devzone/cda/tut/p/id/10383> says is not compatible with Windows7 x64, as I can make my laptop is 64 bit
Thanks for your help
¡Resuelto! Ir a solución.
el 02-06-2012 12:03 PM
Hello diegofernando8891,
what's your LabVIEW version? And which Win 7 edition are you using?
Best Regards,
Ricardo Ramos
NI Brazil
el 02-07-2012 09:34 AM
Hi ... thanks for the attention given to my request.
I tell you that, I fix the problem with the RGT. I had installed Labview2009 (for 64 bits). Because I have 64-bit Home Premium Windows7.
To solve the problem I install labview2009 (for 32-bit) and I could install the TMN.
Now I have another problem,,, I'm programming for a module FieldPoint 1000. But I can not use the function that reads the channel of the module, because I have not installed the Toolkit for this module.
My question is: What should I install toolkit that allows me to use the FieldPoint (to read the FieldPoint channel)?
el 02-07-2012 10:58 AM
Hi diegofernando8891,
I asked you about the LV and Windows version because the LV officialy supports RGT only from v2011. But old versions can work with it too.
About reading the FieldPoint channel, you will need the Real Time module. But you said that you're using LV2009. The FieldPoint 1000 isn't compatible with this version (FieldPoint 1000 only works up to LV8.5).
