cancelar
Mostrando los resultados de
Buscar en lugar de
Quiere decir:
LowSpeed CLIP NI 5761
Hi flote,
I'm curious, when you downloaded and installed the new patch did you also update your project to include the new CLIP?  Please notice that the updated CLIP is version 1.1.0, I believe the one before the patch is 1.0.0.
Kyle S
Regional Account Manager
NI
0 kudos
Mensaje 11 de 16
1.015 Vistas
Yes It's the version 1.1.0. And the results are the same. Error in the map.exe and following fail the instalation. I dont know what's is happening. Have you tried to compile your program with the LowSpeed CLIP and is it works???  😞
PD: Of course, I have the SP1 of LAbView 2010 installed...
Thanks a lot anyway!
0 kudos
Mensaje 12 de 16
1.005 Vistas
A LabView Enginier has solved my problem. Here is the solution:
reinstall the driver
NI FlexRIO Adapter Module Support 2.1.2
http://joule.ni.com/nidu/cds/view/p/id/2399/lang/de
Install the patch
Error, “Compilation failed due to a Xilinx error,” When Using NI FlexRIO
http://digital.ni.com/public.nsf/allkb/BBD7A87F2ADC2028862577FB005F6B19?OpenDocument
Please follow the instructions in the patch
carefully check after restart that the variable
in the system is created
Check if the CLIP version to 1.1.0  is selected.
Stat compiling the files.
0 kudos
Mensaje 13 de 16
989 Vistas
Install the patch
0 kudos
Mensaje 14 de 16
989 Vistas
Hi flote,
That is great to here we got passed the compilation error!  Is everything working and the FlexRIO operating in the proper Low Speed Mode?  I am working on making this information more accessible for future users and want to double check that you have everything up and running.
Kyle S
NI
0 kudos
Mensaje 15 de 16
975 Vistas
Hi KyleTTU,
Yes the CLIP is working properly in the LowSpeed Mode. So now I can choose a lower sample clock!
Thank you for everthing!
0 kudos
Mensaje 16 de 16
972 Vistas
