cancelar
Mostrando los resultados de
Buscar en lugar de
Quiere decir:
Is it possible to get data in excell from USB-1608FS every 1 sec.?
I work with the USB-1608FS and i know that the minimal block size is 31, and that it is recommendable to have a range of frequency from 1 to 10 times bigger than the block size (if i need a bigger frequency i can change the block size to 62, 310, etc..), but my problem its that I need to get data every 1 second (1 Hz).
I tried to put a relay controled by a trigger for to get data every second but, DasyLab displays me the following mistake "Die Zeitinformation die Blocklänge der Datenströme ist unterschiedlich. Diese Kanäle können in diesem Modul nicht verknüpft werden. STOP!" (my language is German, i dont know the exact words in english) and the translation can be: "The time information or the length block of the data is different. These channels cant be united in this Module. STOP!"
Thanks for your Answer.
0 kudos
Mensaje 1 de 2
2.718 Vistas
0 kudos
Mensaje 2 de 2
2.703 Vistas
