Greetings,
I would like you some help: is possible to build 2 independent Labview applications which can communicate through INTERNET by using DataSocket? I need both the client and server to interchange information. Client must be able to send instrumentation information to server and also receive instrumentation information from server. I have checked the example about Building an Interactive Web Page, but in the example all the clients can only see information, I would like the applications to interchange data between them, client writes server (enters information), server writes client, like an internet chat, but sending instrumentation information. Can I embed the client application inside a web browser and have the interchange functionality, where the client not only sees the information but can also enter information?
Thanks a lot for your attention
Saludos desearía cómo puedo escribir dos aplicaciones independients cleinte servidor, utilizando DATASOCKETS para intercambiar información. La idea es que tanto el cliente como el servidor puedan intercambiar datos de control, como una especie de chat. Es decir necesito enviar informaciòn del cliente, procesar en el servidor y reenviar los resultados.
Gracias.
