cancelar
Mostrando los resultados de
Buscar en lugar de
Quiere decir:
I can read data excel dynamically from another PC which doesn't have Lookout?
0 kudos
Mensaje 1 de 4
3.190 Vistas
You can use exemple of the following link.
http://zone.ni.com/devzone/cda/epd/p/id/3409
Abel Souza
National Instruments Brazil
Abel Souza
Engenheiro Eletrônico
LabVIEW User since 8.5
0 kudos
Mensaje 2 de 4
3.165 Vistas
Hi Abel,
Thank you to respond,
I have two PCs  one installed the lookout 6.1 and other an application in Excel, how  I read the data  fron de excel?
Manbe
0 kudos
Mensaje 3 de 4
3.161 Vistas
You can use this article.
http://zone.ni.com/devzone/cda/tut/p/id/4531
Abel Souza
NI Brazil
Abel Souza
0 kudos
Mensaje 4 de 4
3.156 Vistas
