cancelar
Mostrando los resultados de
Buscar en lugar de
Quiere decir:
Front panel indicators used as controllers and viceversa
It is possible to use indicators also as controllers?
I would like to load data from a file and then to be able to edit that data.
Kind regards
0 kudos
Mensaje 1 de 4
4.412 Vistas
Hi vick217
this is the Spanish board. But I think  a "Local Variable" or a Value "Property Node"
could work for you.
Regards.
0 kudos
Mensaje 2 de 4
4.405 Vistas
Dear all,
I am using a PXI 7350 hardware to generate a PWM signal. The PXI is capable of generating this PWM signal by selecting parameters in the configuration VIs from the NI motion 73xx software.
There are a 14 frequencies that can be used. These are:
Clock Divider
Value
Clock
Value*
NI 7334/42/44
Clock Frequency
NI 7330/40
Clock Frequency
NI 7350
Clock Frequency
512 0 40.00 kHz 48.46 kHz 48.01 kHz
1K 1 20.00 kHz 24.23 kHz 24.00 kHz
2K 2 10.00 kHz 12.11 kHz 12.00 kHz
4K 3 5.00 kHz 6.06 kHz 6.00 kHz
8K 4 2.50 kHz 3.03 kHz 3.00 kHz
16K 5 1.25 kHz 1.51 kHz 1.50 kHz
33K 6 625.00 Hz 757.14 Hz 750.09 Hz
External Clock/256 Hz 7 External Clock/256 Hz External Clock/256 Hz External Clock/256 Hz
65K 8 312.50 Hz 378.57 Hz 375.05 Hz
131K 9 156.25 Hz 189.29 Hz 187.52 Hz
262K 10 78.13 Hz 94.64 Hz 93.76 Hz
524K 11 39.06 Hz 47.32 Hz 46.88 Hz
1048K 12 19.53 Hz 23.66 Hz 23.44 Hz
2097K 13 9.77 Hz 11.83 Hz 11.72 Hz
4194K 14 4.88 Hz 5.92 Hz 5.86 Hz
External Clock/ 32,768 Hz 15 External Clock/ 32,768 Hz External Clock/ 32,768 Hz External Clock/ 32,768 Hz
*  These clock value numbers are used for purposes of discussion only.
However, the 375.05 Hz and the ones below are exactly the same as the 48KHz and below, which results in a total of only 7 frequencies. I have tried these frequencies with the MAX software from Labview, and I am able to use the 14 frequencies from the PXI 7350 card. I have also use a PCI 7334 and I was able to use MAX and Labview to configure the PWM.
Do you think that my PXI 7350 card might be damaged?
Best wishes
0 kudos
Mensaje 3 de 4
2.368 Vistas
Hi Vick, thanks for using the forums, I would recommend posting on an English speaking board and writing in a new post to receive a faster response.
As for your problem with the NI PXI 7350 board, you say that with NI MAX you were able to output the 14 different frequencies, but you are unable to do so within LabVIEW? or you are unable to output the 14 different frequencies either in NI MAX and LabVIEW? Could you show us how you are configuring the motion VI's in LabVIEW?
Regards.
Fernando Becerra | CLAD
Fernando Becerra | Field Applications Engineer | National Instruments | CLA | CTD
0 kudos
Mensaje 4 de 4
2.358 Vistas
