el 05-25-2010 10:04 PM
el 06-14-2010 06:24 PM
Hi Mahu, the standard Ethernet port doesn't work with ether cat. Ethercat, is able to use the existing cabling but needs special Ports to work. For example for our Ethercat Expansion Chasis for cRIO, we can use them from industrial controllers, PXI or some CRIO, but not from PC.
You can find more info on this links:
http://zone.ni.com/devzone/cda/tut/p/id/10595
Best Regards
