el 12-30-2013 10:17 AM
Hi everybody
I am using two EVS 1464 RT but suddenly once is not recognized in the MAX, I probe other supply and ethernet cable but doesn't work, also I did a reset with IP Reset and NO APP deep switch up but nothing. Both have static IP direction, I do PING in the working EVS and it response but the other can't response.
I used the NI Network Browser and it detects all the elements with a IP direction in exception of the EVS that is not working.
Really, I don't know what can I do?.... Anyone can help me!!!!
el 01-03-2014 04:44 AM
Hi.
Have you tried to use one at a time or are you using both at the same time? You can test with only one.
You can also test it with another computer. Maybe your firewall is blocking the second IP's.
el 01-03-2014 09:33 AM
I would also suggest double checking to make sure something else doesn't have that same IP address. MAX gets really confused when multiple systems have the same IP. The easiest way to test this is to turn off the EVS and then try and ping the IP address. If something else responds then that is your problem.
el 01-03-2014 10:32 AM
Thanks guys, but look at this.
I did those probes but the solution was clear the BIOS and enter in safe mode, now I can see the EVS in other computer with DHCP IP. But, when I try to set the IP address and install again de software with the MAX appears other problem.
It's related to the hard disk, and it cannot make changes because looking the EVS appears that the primary disk in unavailable and the EVS is connected but without any software installed.
what can I do??
Help please...
el 01-06-2014 05:51 AM
When clearing the BIOS, did you disconnect the HDD or SSHD cable?
You can try to reset your device. If it's necessary, you can try to reinstall the softwares. You can see how to do it in the following link, the "Getting Started with EVS 1464":
http://www.ni.com/pdf/manuals/375155c.pdf
Let me know if you need any more help.
el 01-07-2014 09:26 AM
I followed the instructions of the guide... I think that is like a damage on the SATA unity, don't it?
el 01-08-2014 06:18 AM
Please, answer some questions:
Please, open your MAX, expand the "Remote System" and take a Print Screen from your screen and post it here.
