HOLA BUENAS A TODOS!!!
este es el error que me aparece al intentar crear el exe de mi programa,
This build specification uses VIs from Point by Point which is currently in evaluation mode. During evaluation, LabVIEW is unable to disconnect type definitions and remove unused polymorphic VI instances.
Choose a different option on the Additional Exclusions page and build the application again.
To purchase this product, please contact National Instruments. If you have already purchased this product, select Help >> Activate LabVIEW Components to activate this product.
C:\Archivos de programa\National Instruments\LabVIEW 2010\vi.lib\ptbypt\Filters.llb\IIR Cascade Filter PtByPt.vi
DETAILS
Visit the Request Support page at ni.com/ask to learn more about resolving this problem. Use the following information as a reference:
Error 1073 occurred at AB_Engine_Disconnect_Typedefs.vi -> AB_Source_VI.lvclass:Copy_SourceItem.vi -> AB_Build.lvclass:Copy_Files.vi -> AB_Application.lvclass:Copy_Files.vi -> AB_EXE.lvclass:Copy_Files.vi -> AB_Build.lvclass:Build.vi -> AB_Application.lvclass:Build.vi -> AB_EXE.lvclass:Build.vi -> AB_Build.lvclass:Build_from_Wizard.vi -> AB_UI_Frmwk_Build.lvclass:Build.vi -> AB_UI_FRAMEWORK.vi -> AB_Create_Build_Application.vi -> EBUIP_Global_OnCommand.vi -> EBUIP_Global_OnCommand.vi.ProxyCaller
Possible reason(s):
LabVIEW: This property is writable only when the VI is in edit mode, or this method is available only when the VI is in edit mode.
alguna idea?
