NI Home
Cart Carro | Ayuda
Está aquí:
Responder
Active Participant
alan4
Mensajes publicados: 264
ERROR CREACION EJECUTABLE
HOLA BUENAS A TODOS!!!
este es el error que me aparece al intentar crear el exe de mi programa,
This build specification uses VIs from Point by Point which is currently in evaluation mode. During evaluation, LabVIEW is unable to disconnect type definitions and remove unused polymorphic VI instances.
Choose a different option on the Additional Exclusions page and build the application again.
To purchase this product, please contact National Instruments. If you have already purchased this product, select Help >> Activate LabVIEW Components to activate this product.
C:\Archivos de programa\National Instruments\LabVIEW 2010\vi.lib\ptbypt\Filters.llb\IIR Cascade Filter PtByPt.vi
DETAILS
Visit the Request Support page at ni.com/ask to learn more about resolving this problem. Use the following information as a reference:
Error 1073 occurred at AB_Engine_Disconnect_Typedefs.vi -> AB_Source_VI.lvclass:Copy_SourceItem.vi -> AB_Build.lvclass:Copy_Files.vi -> AB_Application.lvclass:Copy_Files.vi -> AB_EXE.lvclass:Copy_Files.vi -> AB_Build.lvclass:Build.vi -> AB_Application.lvclass:Build.vi -> AB_EXE.lvclass:Build.vi -> AB_Build.lvclass:Build_from_Wizard.vi -> AB_UI_Frmwk_Build.lvclass:Build.vi -> AB_UI_FRAMEWORK.vi -> AB_Create_Build_Application.vi -> EBUIP_Global_OnCommand.vi -> EBUIP_Global_OnCommand.vi.ProxyCaller
Possible reason(s):
LabVIEW:  This property is writable only when the VI is in edit mode, or this method is available only when the VI is in edit mode.
alguna idea?
Knight of NI
Mensajes publicados: 18.064
Re: ERROR CREACION EJECUTABLE
Al usar este sitio Web, usted acepta los Términos de Uso del mismo. Por favor, lea estos Términos de Uso cuidadosamente antes de usar alguna parte de este sitio. Diríjase a este enlace para obtener información sobre la política de violación a los derechos de autor de ni.com.
Mi Perfil | Privacidad | Aviso Legal | Comuníquese con NI © 2011 National Instruments Corporation. All rights reserved.    |    Enviar esta página Enviar esta página
