el 10-18-2010 05:57 PM
Hello.
I just get a new cRio 9012.
I was able to connect the Crio with the computer and get a IP.
I am also able to get a connection with the device using the Measurement & Automation Explorer.
The software installed is:
-labVIEW Real Time 8.2 (I haven't update the to 8.6 because the host only provide licenses to 8.2)
-Language Support for labView RT 1.0.0.3
-NI - RIO 3.2.1
-NI-VISA 4.5.1
-NI-VISA Server 4.5.1
When I try to use the Devices & Interfaces I get two errors:
NI-RIO Error:
error discription
Error -63040 (kRIOStatusRPCConnectionError):A connection could not be established to the specified remote device. Ensure that the device is on and accessible over the network, that NI-RIO software is installed, and that the RIO server is running and properly configured.
For NI-RIO 2.3 and later, refer to Software>>NI-RIO>>NI-RIO Settings under the system in MAX.Prior to NI-RIO 2.3, refer to Software>>NI-VISA>>VISA Options under the system in MAX.
and VISA Error:
error discription
viFindRsrc returned 0xBFFF00A7 (The remote machine does not exist or is not accepting any connections. If the NI-VISA server is installed and running on the remote machine, it might have an incompatible version or might be listening on a different port.)
Please make sure the VISA server is running on the remote machine and that both this machine and the remote machine are plugged into the network.
Possible causes for this error:
1. The remote machine name may be incorrectly specified (either the name was misspelled or the wrong IP address was typed in).
2. The remote machine may not be turned on.
3. The VISA server has not been started on the remote machine.
4. The VISA server was started but is either suspended or is no longer running on the remote machine.
5. Either the local machine or the remote machine is not connected to the network.
6. There is a network configuration problem, such as an improperly assigned IP address, an incorrectly configured routing table, or a firewall between the local and remote machine.
I have a digital module NI 9401 and I don't know how to proceed to fix the error!
Thank you very much!
Paulo Guerra.
10-18-2010 06:19 PM - editado 10-18-2010 06:21 PM
I forgot to attach a error report
