05-22-2012 08:56 AM
I am working with a NI PXI 4132.
I have an issue when i set 0A to source. The programm reurns an invalide value. But it is weird bcause i can set 0V. It works fine.
In 50mA range 40V i will be able to set up current source 0 up to 50mA, isn't it ? Is it true current level cannot be set to 0 ?
Any ideas ?
BR,
Vincent
05-23-2012 12:27 PM
Hi Vincent,
I think this is normal behaviour if we look at the help of NI-DC Supplier :
regards
Romain DUVAL || RF & Semiconductor Staff System Engineer || CLA || CTA
National Instruments France
05-23-2012 01:36 PM
Note that on the 4132, if you want to source 0A, you can disable the channel, which will open a mechanical relay on the output. Also, as the help section above shows, switching to the lowest current setting will allow you to get much closer to '0' A. Hope this helps.
