NI Home
Cart Cart | Help
Hello Events Academic NI Developer Zone Support Solutions Products & Services Contact NI MyNI
You are here:
NI Home > NI Developer Zone > NI Discussion Forums
Reply
Member
Raikar
I have a pcb having only few active passive component I need to measure continuity and the devices I don't want to use PXIe-6556 is it possible program by using DMMs if yes let me know how to program
                  I have a pcb having only few active passive component I need to measure continuity and the devices I don't want to use PXIe-6556 is it possible program by using DMMs if yes let me know how to program,is there any other way to test by using other device which is cost effective than DMMs
Active Participant
Now_With_Underscores
Re: I have a pcb having only few active passive component I need to measure continuity and the devices I don't want to use PXIe-6556 is it possible program by using DMMs if yes let me know how to program
Hey Raikar,
The concept you're trying to implement is called 6-wire resistance measuring.  Here's an article that discusses the concept:
http://zone.ni.com/devzone/cda/tut/p/id/3486
In short, you use an opamp to null out any elements in a particular node that you do not want current flowing across.  Let us know if you have any questions.
-John S
Analog Engineer
By using this web site, you accept the Terms of Use for this web site. Please read these Terms of Use carefully before using any part of this site. Please go here for information on ni.com's copyright infringement policy.
My Profile | Privacy | Legal | Contact NI © 2011 National Instruments Corporation. All rights reserved.    |    E-Mail this Page E-Mail this Page
