Digital Multimeters (DMMs) and Precision DC Sources
How to read values from DMM4040
   I am using DMM4040, NI PXI 6509 device.
I need to make some port pins high which i have already done and now i have to read value captured by DMM then i have to make my port pins low if my value is within limits.
Can u suggest me how to read values from DMM and then by notification i ll make my port pins low.
'' A professional is someone who can do his best work when he doesn't feel like it''...........
(5,851 Views)
What language are you using?  If using LabVIEW, you use the NI-DMM API to communicate with the 4040.  Just take your reading, do your limit comparison, and set your lines based on the comparison results.
GCentral
(5,838 Views)
There is no such thing as a DMM4040 from NI. You posted to the wrong board.
Please post to instrument control and provide the vendor. There are drivers for a 4040 from Tek.
(5,822 Views)
