01-29-2013 03:41 PM
Need expert advise: I need to retrieve Keithley's Measure Function (which could only be Current or Voltage) by polling the instrument.
Usually it is done with a command similar to this: smua.command.
However I checked the reference guide and there is no such a command to get this info.
Any clues?
01-30-2013 10:29 AM
You've posted to a board for NI DMM's - not a place for instrument specific questions. For this sort of question, you should be asking Keithley if you can't find the answer yourself in the manual.
01-30-2013 10:49 AM
No idea why you would ask this in a NI forum instead of the keithley one.
Try:
print(smua.source.func)
01-30-2013 11:28 AM
The forum is for NI DMMs and _Precision DC Sources_, which is the Keithley SMU. I've asked Keithley but have not gotted the response yet.
01-30-2013 11:30 AM
See above.
Try:
This command prints the source function, not the measure function.
01-30-2013 11:32 AM
No. It says 'Additional NI Product Boards'. A Keithley is not an NI Product.
01-30-2013 11:42 AM
When I don't understand a particular device's syntax, I'll take a look at the LabVIEW instrument driver, if it exists (2602 located here), and see what they're doing. Of course, a lot of these APIs just call into a DLL, but usually there's some helpful knowledge in the code. Then you can just port the call over to an equivalent text-based syntax. Hope this helps.
