NI Home
Cart Cart | Help
Hello Events Academic NI Developer Zone Support Solutions Products & Services Contact NI MyNI
You are here:
NI Home > NI Developer Zone > NI Discussion Forums
Reply
Member
MYLONG
which cable NB7 or NB1 is used to connect ER-16 with NI 6503
Hello
Everyone,
I like to get one cable connecting ER-16 channel relay with NI 6503?
Which cable NB7 ot NB1 should I use? Or Do I need a adaptor?
Member
Tunde_S
Re: which cable NB7 or NB1 is used to connect ER-16 with NI 6503
[ Edited ]
Hi MYLONG,
The cabling options for the PCI-6503 are shown in Figure 2 of the ER-16 Data Sheet, which can be found here.
Tunde S.
Member
MYLONG
Hello
Tunde
Thank you for your information
I looked at document
It only said cable 1. I am not quite understanting what it means.
I got one quote, the lady quoted me NB7 cable, she said one end is 26pin for ER-8/16, the other end is 50pin for 6503.
I just want to double check this cable is correct
Member
Tunde_S
The NB1 cable is used for connecting your PCI-6053 to the ER-16. Page 3-9 of the ER-8/16 User Manual better explains the configuration options for the ER-16. Page 2-2 of the manual shows where you connect the 26 pin ribbon (NB7) and the 50 pin cable (NB1).
Tunde S.
By using this web site, you accept the Terms of Use for this web site. Please read these Terms of Use carefully before using any part of this site. Please go here for information on ni.com's copyright infringement policy.
My Profile | Privacy | Legal | Contact NI © 2011 National Instruments Corporation. All rights reserved.    |    E-Mail this Page E-Mail this Page
