11-07-2012 08:35 AM
i need show 2 or more digital input signal from USB6008 in waveform chart, but every signal must have different offset, is it possible, thank you?
11-08-2012 03:30 AM
That means you want to plot two curves to not the same coordinates, am I right? Or how do you mean different offset? Is it offset in X-axis or Y-axis?
Thanks for clarifying.
Jakub
NIEE AE
11-08-2012 10:02 AM
For example : first digital signal start on y-axis 0 (in log "0") and finish on y-axis 1 (in log "1") and second signal start on y-axis 2 (in log "0") and finish on y-axis 3 (in log "1"), do you understand me? Look for attachment, thank you very much.
11-08-2012 10:25 AM
Just add a constant offset to the second signal between the Boolean to (0,1) and the Bundle node.
Lynn
11-08-2012 11:15 AM
Thank you guys !!
