12-16-2013 10:13 PM
Hi every one,,
i want to read my gyro sensor using cRIO9004 and the module NI 9403
is it possible to do so ??
can i have any tutorial or guide to do so ??
thanks
07-16-2015 08:51 AM - last edited on 02-19-2024 04:53 PM by migration-bot
I also want to connect to i2c using NI 9403 ans cRIO 9076
did you manged to do it?
I know that you need to add pull-up ressitor and install i2c driver API avilable online
https://www.ni.com/en/support/downloads/tools-network/download.spi-and-i2c-driver-api.html
also ther is possible way to use full fpga soloution example
https://forums.ni.com/t5/Example-Code/I2C-Bus-Communication-Example-Using-LabVIEW-FPGA/ta-p/3996143
Or Hirshfeld
אור הירשפלד
