I have an ASIC that generates can be an I2C Master or Slave. I want to make it a Master and the USB 8452 and IC slave. I also want the 8452 act as a slave receiver for I2C data that it can receive and plot. What labview blocks would allow me to act as an I2C receiver?
Hi as you can see here: "New Feature: Added support for the NI USB-8452 to be used as an I2C slave device". I recommend installing the latest driver version, then, look at the NI Example Finder under Hardware Input and Output. There should be a folder called I2C and SPI » I2C Slave with examples. I hope this helps
