Digital I/O
usb 6501: 200 Hz noise
Hi
I use the NI USB 6501 device to send trigger signals to a EEG recording system (Nicolet C64 amplifier). As soon as I connect the NI-device to the EEG system (analog Input channel 1), I get very strong noise in the EEG signal at precisely 200 Hz.
Any ideas on what the source of this 200 Hz noise might be?
(4,986 Views)
maybe there is an grounding issue.
This document might help:
http://www.ni.com/white-paper/3344/en/
Is it an digital or an analog trigger?
Work with NI Hard- and Software for about 15 years now.
Certified LabVIEW Developer & TestStand Developer/Architect
(4,961 Views)
Hi
Thanks for the input. I will check possible grounding issues.
The signal is sent to an analag input (ai1) of the recording device.
6501     =>  eeg-device:
Output  =>  ai1
GND     =>  GND
(4,931 Views)
