NI Home
Cart Cart | Help
You are here:
Reply
Member
f90hack
trigger external devices using TTL from PCIe-6259
I have four lasers and I need to trigger any one of them on each iteration of a counter - the laser is selected randomly each time via a random number. I want to send a TTL pulse to the selected laser from the PCIe-6259 card, and I understand it has three DIO ports with 32 lines each. I want to set up 4 digital output channels, but I am not sure how it is done. Can this be done? I am using NIDAQmx ansi C.
Thank you for the help!
Active Participant
snowpunter
Re: trigger external devices using TTL from PCIe-6259
You have a few different options depending on the desired response time from your incoming counter to when you send the TTL signal.
I would take a look at the examples in the Counter and the Digital folder here (assuming you have the DAQmx driver installed):
C:\Documents and Settings\All Users\Documents\National Instruments\NI-DAQ\Examples\DAQmx ANSI C\
CTA, CLD, MTFBWY
My Profile | Privacy | Legal | Contact NI © 2011 National Instruments Corporation. All rights reserved.    |    E-Mail this Page E-Mail this Page
