06-14-2016 10:55 PM
Hello friends,
I have a question. I need to trigger a digital output of Myrio with a single pulse. After the pulse, the output will remain activated. Then with another single pulse, the output will be turned off. What tool should I use?
Thanks for listening ,
David
Solved! Go to Solution.
06-16-2016 12:44 PM
Hi Davi08,
I've made a little research to give to you an answer and I've found another forum at "NI Discussion Forums" that maybe can help you.
Try to use this link,I believe that will help you.
http://forums.ni.com/t5/Academic-Hardware-Products
Best Regards
