Digital I/O
trigger digital output myrio
Hello friends,
I have a question. I need to trigger a digital output of Myrio with a single pulse. After the pulse, the output will remain activated. Then with another single pulse, the output will be turned off. What tool should I use?
Thanks for listening ,
David
(3,348 Views)
Accepted by Davi08
Hi Davi08,
I've made a little research to give to you an answer and I've found another forum at "NI Discussion Forums" that maybe can help you.
Try to use this link,I believe that will help you.
http://forums.ni.com/t5/Academic-Hardware-Products-ELVIS/myRIO-digital-trigger/td-p/3278560
Best Regards
César Teixeira
Certified LabVIEW Developer - CLD
Applications Engineering
National Instruments Brazil
(3,333 Views)
