Digital I/O
synchronize digital output AND digital input NI-USB 6343
Hello
I'm using NI-USB 6343 to drive 1 TTL device. This device can also output a TTL signal to indicate whether the gate is opened/closed.
I'm using Digital Bool 1 Line 1 Point. I was able to flip gate open/close in timely manner. But i Like to sync DI and DO properly.
I tried to throw in OnBoard clock but it was not successful.
Is there any way to sync DI and DOI using onbaord/hardware clock?
Any insight will be great!
Thanks!!
(4,718 Views)
Accepted by topic author nkhoa
Synchronizing your DI and DO tasks should be possible with your device. You will need to time them off of a a clock that is usable by both. This information is available in the X Series User Manual
http://www.ni.com/pdf/manuals/370784f.pdf
pg 6-9 and 6-13
You can also find some information and examples of syncing various tasks in the article below.
http://www.ni.com/product-documentation/4322/en/
Best of luck,
Eric
Eric H.
Senior Field Applications Engineer
NI
(4,625 Views)
thanks!
I got it working!
(4,334 Views)
